Recently on twitter Jon Raymond asked about a firmware update for the older versions of the badge. My hesitation was big until this point, since I thought the charlie-plexing would take up too much space alone, to integrate animations like I did with the newer 0805 version of this badge. As you can see here, I've logged a bit about the progress over on twitter https://twitter.com/davedarko/status/959491261903310848.
I was able to put 7 animations onto the badge! If you want to try out some other animations on the push of a button, you now can!
- added 7 animations, cycling through on push of a button
- removed digitalWrite and pinMode functions and replaced them with setting appropriate registers
- converted every int to 8bit / 16bit unsigned integers where I could
Download the hex - file from the download section and upload it to the attiny via:
#!/bin/bash
avrdude -c usbasp -p t13 -U lfuse:w:0x3A:m -U hfuse:w:0xFF:m -B 2000
avrdude -c usbasp -p t13 -U flash:w:KITTiny.ino_attiny13_9600000L.hex
You need to solder a button between the PB4 Pad and GND and find a good spot to glue it down. Have fun :)
slow chaser
fast chaser
K.I.T.T. persistance of vision (I'm really bad at this)
cross fader
cross fader beam
police flasher
computing (counting up in binary)
No release notes?
hm. no. not sure if they're necessary? basically completely rewritten software..
But why would I want to upgrade then? So that I had the knowledge that the code blinking the LEDs now does the same thing much more elegantly? Is there any visible difference?
okay, I understand now :) is it okay to post it here? I'll just start writing it here :D
Awesome!
