Spacers is here
09/01/2017 at 07:57 • 0 commentsThat was a very long delivery, but finally - spacers is here. Now I try to find spatial configuration of the 18650 batteries, because internal space of the battery compartment is limited. Max height is 40mm, length and width limits is about 240 mm.
Tilt sensor conception test
07/30/2017 at 21:39 • 2 commentsHello again! Today I built tilt sensor prototype for testing. It based on very easy principle - moving Hall sensor in magnet field. Sensor have a very simple construction - neodimium magnet is glued to pendulum and moving around Hall sensor. -
First 3D view
07/25/2017 at 22:56 • 0 commentsHello for everyone! This was a long evening but I did it. Simplified 3D model is ready. Of course this is not final construction, but now you can look at approximatly view and imaging how project is will be.
Few words about gearbox
07/24/2017 at 05:14 • 0 commentsHi! In previous log I told about problem with connection gearbox to shafts, but I don't shown and explain what gearbox is. Transmission consist of two stages, first is gearbox from cheapest cordless screwdriver, which include planetary gear, second is are pair of gears from two different bicycles and chain.
The planetary gearbox consists of two stages, the gear ratio is about 7.9 for each of them. I will use only one and for connecting this gearbox to motor shaft I need to replacing carrier of this stage for new one with muff. Plus second output carrier must be replaced by custom to connecting to small gear from bicycle.
Pair of the bicycle gears I will use for transmission torque from motor shaft to wheels. This pair have a small ratio is about 1.5.
Another day - Another challenge
07/23/2017 at 20:17 • 0 commentsHello! Today I was busy by housework, but found time for assembling motor driver board. I using perfboard for that, because I have possibility add some elements in circuit without etching new pcb. My motor driver board based on L6203 IC from ST, I used this chip before and it was a good experience. In start of the project, I wanted build motor driver on discrete MOSFETs, but it given me problem like needing separate radiators for cooling, I can't screw all transistors on one radiator or electronics enclosure, it will shorted the circuit. In case with L6203, I've all I need in one IC, which I can just screwing to enclosure and don't need additional radiator.
When I almost assembled this board I realise that all my previous experience was for very simple and stable application, but now motor driver will be in balancing board which means - frequently switching of direction and possibilities for inducing parasitic induction currents in output circuit of the driver. In application notes for this one, ST told that you need using snubber network (look applied picture). This network is drop the voltage which induced by motor own induction in moment of switching H-bridge FETs of the motor driver.
I don't have needed components for build it and I will try to visit local store tomorrow.
First materials
07/22/2017 at 19:18 • 0 commentsToday I visited local hardware store, and bought some materials for project: barrow wheels and aluminium profiles, drawings are almost ready, on next week I'll started assembling frame.
Seek or Make
07/20/2017 at 08:33 • 0 commentsHello for everyone! Project ongoing, I thought about connections of gears to shafts a long time, seeking in store components which can fit for that. But now I decided to make some blueprints and give it to local factory, after that I will have details which perfect for my project.
Work in progress
07/18/2017 at 19:04 • 0 commentsI don't have so many time but now I working on 3D model. Have some problem with connection of gearbox to DC motor.
