FAR
Fixed-rate Asynchronous Receiver. Extremely simple asynchronous serial input to parallel data output converter.
FAR is a simple circuit that can be connected to the RS-232 serial port of a computer to convert RS-232 RxD to 8 bit values and can be used e. g. to add LCD display to your PC. The circuit uses only two 555 timers and one shift register. No Raspberry Pi, no Arduino, no MCU.
The difference between this circuit and other similar projects is that this project does use the TxD pin of the COM port and it does not require any complex IC. All other projects that I found either use programmed microcontrollers or bit bang the meta signals (DTR or RTS) of the serial port. With this circuit you simply send the data to serial port.
The circuit consists of two 555 timers. The Start bit of the TxD signal of the serial port triggers the first 555 in monostable mode (byte timer). The output of the byte timer enables the second 555 (bit timer) by disabling its ~reset signal. The bit timer then generates the clock for the asynchronous TxD data to be stored in the shift register. At the end of the timing period the byte timer stops the bit timer by enabling the ~reset of the bit timer so that the bit timer generates exactly 9 clock pulses: 1 Start bit + 8 data bits. At the same time the byte timer output (the end of the timing period) enables the strobe signal of the shift register. The 9th clock pulse shifts the 8th data bit into the shift register and at the same time it shifts the Start bit out of the shift register before the strobe signal puts the internal contents of the shift register to the output pins of the IC. The byte length and bit clock frequency are fixed and pre-defined by used parts for the monostable and astable 555 timer respectively. The circuit was successfully tested at 9600 bit/s.
Please right-click the above image and select "View image" to see the schematics.
Timing diagram:
  • The Start bit of the asynchronous data (serial port TxD) triggers the Byte timer
  • The Byte timer starts the Bit timer
  • The Bit timer generates clock pulses that shift the asynchronous TxD data into the shift register
  • The Byte timer stops the Bit timer
  • The Byte timer generates strobe signal for the shift register
The red lines in the timing diagram represent important delays:
  1. The byte timer period must end before the bit timer generates 10th clock pulse rising edge
  2. The shift register strobe must follow the rising edge of the last bit clock pulse
Please note that this circuit exploits the charasteristic of the 555 astable mode - the first pulse (time high) is longer than the following pulses as the timing capacitor must charge from 0 V to 2/3 Vcc but for the rest of the operation it has to charge only from 1/3 Vcc to 2/3 Vcc. This provides the important delay of the clock pulses for the shift register without additional circuitry.
The shift register stores and outputs the byte, the NPN transistors invert the signals as needed and at the bottom right corner of the schematics, there's a pin header to connect a HD44780 LCD display that can be driven by special serial data (HD44780 data and commands are converted in software to the waveforms for the HD44780 input pins). I wrote a simple C program to control the LCD and output texts to it and later a small Windows utility to show IP address and CPU load on the attached LCD.
LCD.zip
Linux source for a command line tool to drive connected HD44780 display.
x-zip-compressed - 1.44 kB - 12/11/2021 at 07:16
Download
  • 2 × 555 timer
  • 1 × 74HC595 shift register
  • Uploaded source code for LCD connected to FAR
    Filip12/11/2021 at 07:20 0 comments
    Uploaded a Linux C source code of a tool to drive a HD44780 display connected to PC using FAR.
  • Schematics and detailed description
    Filip12/27/2014 at 22:43 0 comments
    I've added the schematics and detailed function description. I'll also add the waveform details and timing adjustment instructions - unfortunately an oscilloscope is needed to exactly match the serial port TxD, byte and bit timers. I hope that the need for oscilloscope can be eliminated by adding some LEDs and using software to feed special calibration patterns to the serial port.
  • Second prototype testing
    Filip08/19/2014 at 16:21 0 comments
    The tests were complicated by the fact that Chinese manufactured transitors are of very low quality. The ones already on the board had to be desoldered, new ones tested and placed. Due to a stupid mistake 4 PCB traces are missing, but that can be fixed quickly and proceed with tests. The software will be modified as the second prototype uses different bit ordering. The original was rather counter-intuitive.
  • Second prototype
    Filip08/19/2014 at 16:16 0 comments
    Second prototype does not use the 7400. It is replaced with 2 transistors and the PCB is slightly redesigned.
  • Initial prototype testing
    Filip08/19/2014 at 16:15 0 comments
    The first prototype was successfully tested, it is able to drive an LCD display with a specialised software written in C.
  • Initial prototype
    Filip08/19/2014 at 16:14 0 comments
    The first prototype uses 556 dual timer and 4094 shift register. For signal inverting it uses 7400.
View all 6 project logs
VertOlive wrote 01/18/2022 at 23:27 point
It’s a really clever solution like zpekic said.
What about skyrocketing your protocol and try to improve the baudrate of your schematics ? Or make it serial to parallel without the LCD by adding pin or a small flat ribbon cable ?
Have a nice day !
Filip wrote 01/19/2022 at 19:06 point
Hi, thanks. Yes, it definitely can be run at a higher baud rate, but at the same time it makes it more challenging to tune the required timings. It would also make it more sensitive to temperature changes etc. For adding an LCD display to a computer case this is the sweet spot.
The prototypes i built actually have a pin header, so it can be used for generic async serial to parallel connection.
zpekic wrote 01/18/2022 at 17:49 point
Clever solution! I know 555 is all the rage now, but could 2 of them be replaced by single 74x221? https://www.ti.com/product/SN74221
Filip wrote 01/19/2022 at 18:49 point
Thanks. To be honest, I'm not sure about the 74x221. But I actually used one 556 instead of two 555s in the second iteration of the design.
