Second prototype testing
A project log for FAR
Fixed-rate Asynchronous Receiver. Extremely simple asynchronous serial input to parallel data output converter.
filipFilip • 08/19/2014 at 16:21•0 Comments
The tests were complicated by the fact that Chinese manufactured transitors are of very low quality. The ones already on the board had to be desoldered, new ones tested and placed. Due to a stupid mistake 4 PCB traces are missing, but that can be fixed quickly and proceed with tests. The software will be modified as the second prototype uses different bit ordering. The original was rather counter-intuitive.
