Getting the right voltage
07/22/2017 at 14:10 • 0 commentsVoltage Issues
One of the hassles with this and the Arduino is that the arduino is 5V and the nRF runs at 3.3v . There are a few carriers out there, but i wanted something really small and easy. So I'm using the voltage drop across a LED to power this. You'll need one of the normal size LED's and they drop just under 2v and also provide a visible indicator as it will pulse as the nRF goes about its business.
Basis
07/20/2017 at 12:58 • 0 commentsafter making many robot projects I needed a simple way to contro them. It started to become too costly to use rx gear.
This uses a nRF smd chip and an Arduino pro mini and the rf24 libray which as well as providing point to point rx/tx also gives mesh capabilities with rf24mesh.
The first step was making a quick and easy two comm link with rf24 and Arduino pro mini.
