A brief update. I've just finished working on a new version of the motor control firmware to give more precise, faster control. Here is an example of the results:
The motor controllers are now estimating the desired velocity from successive positions, which keeps the position on target without increasing the latency in processing position commands. The controllers also now have the option for a feed forward term for the motor torque, but that isn't used here.
That looks cool!!!
Never thought we'd see 3D printed gearboxes.
Well this looks awesome
Thanks!
That looks like it should be able to do some prancing and other dynamically stable gaits. Great!
I really hope so! I want to do another iteration on the motor controllers, but these should be good enough for the moment.
There is so much that can be done with those, including motion profiles, regenerative braking, complaint motion and feedback — mind boggles.
