We've been trying some simple gaits animations to prove the robot can walk independently. These run through a fixed set of movements without any feedback, this is the first one that worked so there is a huge room for improvement. It falls over in the end of the video because of a problem with one of the motor controllers, it shouldn't take too long to track down and sort out.
Charles Galambos
excellent !
Thanks!
Congrat!! very cool!
Thank you, hopefully more coming soon!
That doesn't look too good. Is it power problems?
We had it walking for about 5 minutes before the video. At the end one of the motor controllers cut out, I am adding more diagnostics to work out why.
The legs have some give in them, which wasn't accounted for properly the first time it was walking. With a bit of tuning it will be much better.
Oh, I see, I wasn't sure if it's the legs or the motors. This is good news, because in the worst case you can just make the legs more rigid.
