13D Printing Notes
Most of the components in the project are printed in PLA with the exception of parts directly in contact with motor which will be made from ABS.
PLA Printer setup:
- 0.3 mm layer height
- 20 % infill
- Honeycomb fill pattern
- 0.4 mm Nozzle diameter
- Keep fan speed down to 20 to 30%, improves layer adhesion
- Print on the hot side, typically I use 220, again to improve layer adhesion
