Hackaday.io Hackaday.io
Sign up Log in
RooMQTT
You all know that moment when you discover that your houshold device you got for free is fully hackable.
tilloTillo
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
4 followers
  • Description
  • Details
  • Files 0
  • Components 7
    • View all
  • Logs 2
    • View all
  • Instructions 0
  • Discussion 0
  • The 2018 Hackaday Prize
871
0
4
4
Team (1)
  • tilloTillo
Join this project's team
hardware
Software
ongoing project
Roomba micropython 2018hackadayprize
Related lists
2018 THP: Digikey Parts
Hackaday Prize entries using Digikey parts
This project is submitted for
  • Robotics Module Challenge
This project was created on 07/24/2017 and last updated 8 years ago.
Description
Since the Micropython attempt failed, see log, and i still have the hardware laying around, I tought it could be usefull to control my Roomba over MQTT.
Components
  • 1 × Wemos D1 mini because they're small and cheap
  • 1 × BOB-12009 bi-directrional logic level shifter
  • 1 × R-785.0-0.5 Linear Regulator Replacement DC DC Converter 1 Output 5V 500mA 6.5V - 32V Input
  • 1 × MD-70 Mini DIN 7 Male connector, Mini DIN 8 is fine as well
  • 1 × Stripboard, headers and wires
View all 7 components
Project Logs
Collapse
  • Resources
    Tillo • 05/03/2018 at 19:32 • 0 comments
    Serial protocol definition.
    http://anrg.usc.edu/ee579/spring2016/Roomba/iRobot_Roomba_600_Open_Interface_Spec.pdf
    Arduino Roomba library
    http://www.airspayce.com/mikem/arduino/Roomba/
  • Sometimes things doesn't work
    Tillo • 08/07/2017 at 08:59 • 0 comments
    Yep it happend. After getting all the parts, some soldering, charging the Roomba, testing all the voltages (remember there are 14 to 18 VDC coming out of the Roomba, that would release the magic blue smoke super fast), connecting the ESP8266 Module, settings up the webREPL and firing the first commands nothing happened.
    After connecting there the UART of the module to a UART-USB cable I saw that it actually echoes all the stuff I sent over webREPL. Damn it.
    I will try it with using UART1 for TX and UART0 for RX, since UART1 is only unidirectional.
View all 2 project logs
Log In/Sign up to comment
Sign up with Github
OR
Here I build a external GNSS module for mobile devices without or unsatisfactory navigation GNSS option.
Project Owner Contributor
GNSS bluetooth module with u-blox NEO8N
dechemistdechemist
Set an hc-05 bluetooth module to master mode to send serial data to another module.
Communication between two hc-05 Bluetooth modules
backlunpbacklunp
Simple development tool for wireless applications based on the NRF24L01+ 2.4GHz transceiver module and ATtiny814
ATtiny814 NRF2USB
stefan-wagnerStefan Wagner
A cheap and easy IrDA SIR adapter
SIR IrDA Lot
ziggurat29ziggurat29
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "RooMQTT", please tell us the reason.
Send message
Remove Member
