I've now finished wiring everything up and the screen, buttons and sound all work, so what's next?
- The aperture for the screen is slightly too large, exposing a little too much of the non-displaying part of the screen at the bottom. A small adjustment to the case front will fix this.
- It's too easy to unintentionally press a diagonal on the dpad. I think that this is because it is a little too small and moves around too much in its hole. Hopefully making it slightly bigger should fix this.
- Complete the case front and design a back for it.
- Re-print the external parts in their final colours.
- Programming. Lots of Programming.
David Boucher
I can't wait to see the first game you make for it!
