1Build Instructions with Photos (this is probably the only document that you need)
2Requirements / Use-cases (helpful if you want to modify or enhance the project)
3Design (helpful if you want to modify or enhance the project)
4Software Image Creation Instructions (helpful if you want to modify or enhance the underlying OS and components)
