that time
08/01/2017 at 19:29 • 0 comments..when you have deleted the conversion of negative numbers to positive and spend half a day figuring out why the ESC's keep dropping sync with the attiny84...
rev2 has a minor glitch
07/31/2017 at 22:31 • 0 commentsI have finalized the electronics, printed a chassis and stitched it all together. It runs off a pack of 4 LiFePo4's in parallel using 2 boost converters, one for each motor. The boost converters are set to give out 12.2 volts as the ESC's can't handle more than 12.6 volts. The weaksauce china motors are rated at 12 volts.
The glitch is a software glitch. When reversing it slows down the opposite belt. I have a routine in comment for full reverse, I guess I'll have to use that somewhere in the code to slow down the correct belt when both are in reverse mode. Also I want to limit the right/left impact on speeds cause it's crazy turning. I'll add some more pictures later.
RC PWM is not the PWM you are used to :P
07/29/2017 at 22:18 • 0 commentssoftware revision 1 is almost a complete failure
Non-ICE
