This electronic key may be used to drive a door lock or a security alarm. If all keys are pressed in the right sequence, the output of the gate number 5 (IC2, pin3) turns on and through a transistor activates the unlock relay.
As you can see in the logic diagram, the gate number 5 gets high if the 5th key is pressed and the gate number 4 is on (due to the AND gate number 9); the previous stages work in the same way.
Each of the gates number 10, 11, 12, 13 turns on if a key (from 2 to 5) is pressed and the previous stage (gates from 1 to 4) is off, in other words when you press a wrong button; if that happens a reset signal will lead the circuit to the start condition.
To full understand how this electronic key works you may visit this simulation board.
Andrea De Napoli
Jan
Michael Gardi
Jeroen Brinkman
