Laser Exposer Diode Driver.pdf
Schematic for the diode driver. A resistor has been added to limit max base current in the driver transistor - to avoid frying the opamp if powered up when no diode is connected.
Adobe Portable Document Format -
32.96 kB -
01/29/2019 at 08:44
