Smallest AVR ISP Programmer
This programmer is only 3 cm long and 1 cm in diameter. It is so small, it can be builtin din-6 plug
I just wanted to shrinkify already existing avr programmer so it can be hide in connector case (DIN6 in this case but it can be another as long as you can fit all the elements). In my project I used FabISP firmware in ATTiny44.
  • 1 × ATtiny44 Microprocessors, Microcontrollers, DSPs / ARM, RISC-Based Microcontrollers
  • 2 × 3v6 Zener diode
  • 2 × 68om resistor
  • 1 × 1k5 om resistor
  • 2 × 22p capasitor
View all 7 components
oshpark wrote 09/07/2017 at 05:45 • point
Impressive!
davedarko wrote 08/15/2017 at 08:48 • point
I should say challenge accepted and design something with a tqfp atmega328 :D but I don't ;) nice work, it's always a good thing to decide on one connector and stick with it. I put smd pads on my boards and use pogo pins on my programmer - but your choice to go with DIN-6 is interesting.
Marcin wrote 09/06/2017 at 21:52 • point
Sorry for the late response (Holiday). Nice to see any feedback. I used din-6 connector just because it nicely fit my transmiter case (I removed power input and replaced with data connector).
Arya wrote 08/15/2017 at 07:41 • point
Nice! IMO you could experiment with SMD parts to make it even smaller - SMDs are actually quite easy to work with =)
Marcin wrote 09/06/2017 at 21:57 • point
At the time I couldn't buy SMD crystal rezonator at my local store, but I wanted to do it i one day.
K.C. Lee wrote 09/07/2017 at 11:35 • point
Not so with regular HC49 crystals when through hole version is smaller than SMT.  There are some 5x7 ones and may be smaller ones, but are difficult to find and cost a bit more.
I have switched to much cheaper and smaller watch crystal cylinder style 12 and 16MHz for the last couple of projects.  https://www.aliexpress.com/item/Free-shiiping-20pcs-2-6-16MHz-Error-20ppm-20pF-Cylinder-quartz-resonator/32323805290.html  2mm dia x 6mm long
