This programmer is only 3 cm long and 1 cm in diameter. It is so small, it can be builtin din-6 plug
I should say challenge accepted and design something with a tqfp atmega328 :D but I don't ;) nice work, it's always a good thing to decide on one connector and stick with it. I put smd pads on my boards and use pogo pins on my programmer - but your choice to go with DIN-6 is interesting.
Sorry for the late response (Holiday). Nice to see any feedback. I used din-6 connector just because it nicely fit my transmiter case (I removed power input and replaced with data connector).
Nice! IMO you could experiment with SMD parts to make it even smaller - SMDs are actually quite easy to work with =)
At the time I couldn't buy SMD crystal rezonator at my local store, but I wanted to do it i one day.
Not so with regular HC49 crystals when through hole version is smaller than SMT. There are some 5x7 ones and may be smaller ones, but are difficult to find and cost a bit more.
I have switched to much cheaper and smaller watch crystal cylinder style 12 and 16MHz for the last couple of projects. https://www.aliexpress.com/item/Free-shiiping-20pcs-2-6-16MHz-Error-20ppm-20pF-Cylinder-quartz-resonator/32323805290.html 2mm dia x 6mm long
Impressive!
