First Update
08/07/2017 at 06:59 • 0 commentsI have finished the first prototypes. Now is the time to share. The boards work great charging and the buck booster keeps the Pi running smoothly. Now it is time to focus on the software side. The MAX17043 has no real software to run on the Pi. I used some examples and did a lot of simple serial test with an Arduino. Nothing has been done to use the Pi to monitor the battery.
Mr. Spriggs
