Hackaday.io Hackaday.io
Sign up Log in
stranger things badge
using some tricks I learned to create a pcb
davedarkodavedarko
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
4 comments
11 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 2
    • View all
  • Instructions 0
  • Discussion 4
View Gallery
663
4
11
12
Team (1)
  • davedarkodavedarko
Join this project's team
  • https://github.com/davedarko/Stranger-Things-Badge
ongoing project
This project was created on 08/11/2017 and last updated 9 years ago.
Description
using a yellow pcb, add some LEDs on the back like my wordclock pcb and figure out how to control them (possibly an esp12, I would need 6 pins for charlie plexing the 26 letters)
Project Logs
Collapse
  • pretty neat idea from comments
    davedarko • 08/19/2017 at 20:13 • 0 comments
    https://playground.arduino.cc/Code/ADCTouch
    thanks @Clayton G. Hobbs , I'll look into that :)
  • so it begins
    davedarko • 08/19/2017 at 09:34 • 0 comments
    I've made some screenshots to get started, to anyone interested: watch episode 3 of season 1 to get colors and fonts and wallpaper colors!
View all 2 project logs
Log In/Sign up to comment
Sign up with Github
OR
Clara Hobbs wrote 08/19/2017 at 19:19 • point
Ooh, here's an extravagant idea!  Add some sort of touch sensor for each letter (capsense pads?), then make it so you can pair a badge with another and light up the other badge's letters by touching yours.  Maybe add an accelerometer, then make it so you have to turn your badge upside-down to communicate.
davedarko wrote 08/19/2017 at 19:36 • point
these are some golden ideas :)
Bastiaan wrote 08/11/2017 at 14:21 • point
Are you planning on making it like the Christmas lights with letters underneath them?
davedarko wrote 08/11/2017 at 16:08 • point
yep, maybe an ESP12 that "reads" stranger things tweets... but this is just an idea drop, I'll hack something together on vacation :)
This blinky badge is ideal place to start with SMD components, PCB design and manufacturing
Project Owner Contributor
"Get into SMD" badge
vincent-stuchlyvincent stuchly
A girl is standing on the balcony, admired for her beauty and innocence.
BalconyJuliet
ndgaragendGarage
Make a custom PCB ruler using my open source PCB rulers
Make your own custom printed circuit board ruler
ian-dunnIan Dunn
RGB LED-strip driver using PIC16LF767 and ESP8266. Control via Android app.
RGB LED-strip driver over WiFi
bertvanoBertVano
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "stranger things badge", please tell us the reason.
Send message
Remove Member
