PCF8574 - wait what?
A project log for LAMEBOY - another ESP12 handheld
fully portable ESP12 project with battery charging and power muxing
davedarkodavedarko 08/15/2017 at 22:524 Comments
Although I had my run on some designs using this chip, I had to check the datasheet again and noticed something weird. Everyones project I've seen just uses a button that pulls the pin to ground. But what can we observe here on P5? A pull-up resistor of 100kOhms pulls up the input, until  you push a switch that connects it to even more pull-ups? I should sleep and tomorrow remove my pull-up stuff from the board.
https://www.mikrocontroller.net/articles/Port-Expander_PCF8574
#D1 Mini X-Pad Shield
#HariFun#133 More I/O Madness
#Portable Raspberry PI Zero
Rich text editor
deʃhipu wrote 08/16/2017 at 12:10 point
That makes little sense. Maybe they meant Vss in there?
davedarko wrote 08/16/2017 at 13:47 point
indeed. but that's also a lot of resistors to add, if they're really needed.
davedarko wrote 08/16/2017 at 21:46 point
yep, I'm aware of them - but I go the easy route with just switch to ground for now. I still have 4 arrays on there.
