Although I had my run on some designs using this chip, I had to check the datasheet again and noticed something weird. Everyones project I've seen just uses a button that pulls the pin to ground. But what can we observe here on P5? A pull-up resistor of 100kOhms pulls up the input, until you push a switch that connects it to even more pull-ups? I should sleep and tomorrow remove my pull-up stuff from the board.
https://www.mikrocontroller.net/articles/Port-Expander_PCF8574
That makes little sense. Maybe they meant Vss in there?
indeed. but that's also a lot of resistors to add, if they're really needed.
https://www.aliexpress.com/item/100pcs-10K-Ohm-10-Kohm-5-0603-8P-2-4P-SMD-Thick-Film-Chip-Resistor-Network/32767249452.html
yep, I'm aware of them - but I go the easy route with just switch to ground for now. I still have 4 arrays on there.
