1Build instruction of Visioneer 2.0
In this build instruction video, we show the process of making Visioneer 2.0. in 3D printing, polishing/sanding, spray painting, soldering, and assembling.
2Assembly of Visioneer frame to pre-wired components
Video walks user through assembling a set of components onto one side of the prototype frame. NOTE: we have transitioned away from using the sonar, so you will see only the LIDAR in this video. Also, the power carrier position has changed to behind the main carrier (see current gallery), rather than next to it, as shown in this video.
3Quick OpenCV installation
Claude Pageau's instructions: https://github.com/pageauc/opencv3-setup
MakerVisioneer
