Specifications
- MCU – SiFive Freedom E310 (FE310) 32-bit RV32IMAC processor @ up to 320+ MHz (1.61 DMIPS/MHz)
- Storage - 128-Mbit SPI flash (ISSI IS25LP128)
- Expansion - 2x 14-pin headers with JTAG, GPIO, PWM, SPI, UART, 5V, 3.3V and GND
- Misc - 1x reset button, 16 MHz crystal
- Power Supply - 5V via pin 1 on header; Operating Voltage: 3.3 V and 1.8 V
- Dimensions - 38 x 18 mm (estimated)
- License - CERN Open Hardware Licence v1.2
Michael Welling
J. Ian Lindsay
Stefan Kremser
NuclearPhoenix
After some googling I found the following guide explaining how you can use your J-Link with this board:
https://wiki.segger.com/GroupGets_LoFive_R1_1
I hope this is useful for some of you.
