The upgraded version of the WiFi Satellite features new software and new hardware!
If you haven't seen the first version, view it here!
Hardware changes
We're now using the updated Packet Monitor V3 board by Travis Lin.
The new version adds a Neopixel (WS2812B) RGB LED and a 3 way slide switch on the side.
You can check out Travis Boards at Tindie! Just be aware that designs change and the latest Packet Monitor board might look a bit different than the ones we use right now.
Software changes
Thanks to the powerful ESP32 and the added slide switch on the board, I (Spacehuhn) wrote a firmware that features a new user friendly menu with way more information about the captured traffic than before!
All boards can also be controlled using simple commands over the serial connection. This solves one of the biggest problems we faced last year with our first build. Now we can sync the time with all boards! So no more .pcap files from 1970 :D
It also makes debugging way easier and we can controll all boards at the same time without hassle.
Stefan Kremser
NuclearPhoenix
Andrej
Michael Welling
Vitaly
