The FoneTroll is customizable to use a variety of wireless communication methods. Developed primarily for multicopter use, this project will focus on options for these UAVs. For FPV multicopters, a good communication solution is found using the Open Pilot hardware or a custom solution that uses another wireless solution. Some options will be discussed further in the project logs.
The case has been modelled in 3D for printing and machining in a variety of materials.
We will explore ergonomics, range and device compatibility in this project.
ken.do
