It is alive!
09/27/2017 at 18:59 • 3 commentst
Rewiring the stator was a success.
Now more speed/power!
Maching some new parts for the BLDC
07/20/2017 at 23:21 • 0 commentstsMilling of the BLDC motor plate:
Milling the new driveshaft:
Going BLDC!
06/26/2017 at 23:09 • 0 commentsI found a Brushless Washer motor on Ebay, and am going to use this for the drivetrain.
Brushed had too many problems at higher RPMs / prolonged usage.
Stay tuned!
MkV: The future
08/21/2014 at 17:47 • 1 commentThis is the current version in progress. It will include improved interactivity, as well as better position sensing via the gyroscope.
It's Alive!!
08/21/2014 at 17:44 • 0 comments![]()
MkIII: Aluminum Ring
08/21/2014 at 17:44 • 0 commentsA whole new design with drivetrain was drawn up in Solidworks and created at Makerplace and FablabSD (it's current home).
This new version adds:
a lightweight aircraft grade aluminum ring
CNC machined drive train
3HP AmpFlow brushed motor
Kelley controller with 0-5v sense for power
2x750 watt drive PSUs ( from robotics)
RPM control via Arduino, hall effect sensors and an R/C pass 0-5 Speed controller signal
physical positioning via a MPU-6050 ( for low RPM POV)
serial bluetooth position sending to processing
Drivetrain with Idler installed
Plasma'ed piece on ring assembly
Welder with the finished Al ring!
Rotating Electronics
Communications Diagram
Electronics Schematics
MkII: Wooden "Art" Ring
08/21/2014 at 17:43 • 0 comments![]()
We needed something a little stronger, so we created a CNC version of the ring with intersecting parts, wrapped in a custom aluminum band.
This was the version we shipped out to Youtopia!. Our ring was 5x as heavy and burnt out our drive mechanism (drill). Efforts were made on-site to hack a brushless drill to power the contraption, but fell short. Festival participants could spin the wheel manually as well as interact with the colors via the Leap Motion.
This iteration utilized a drill potentiometer for speed control, it was mostly either on or off.
MkI: PVC Ring
08/21/2014 at 17:42 • 0 commentsWe started off with just a PVC ring powered by an old drill. The pixel pusher network, slip-ring and interactive layers in processing were created during this stage.
Crucial piece: the high RPM slip ring
Here is the finished prototype taken slightly before the core snapped.
boolean
