Today I soldered the PCB together after doing a minor code check on a bread board. The particular NodeMCU boards I had bought from eBay required me to push and hold the FLASH button, press and release the RESET button, and then flashing the firmware.
I managed to burn out 2 boards when I accidentally connected A0 and D0 in series. Don't do that.
To get the NodeMCU board going with Arduino, you need to add:
http://arduino.esp8266.com/stable/package_esp8266com_index.json
To the additional boards manager in preferences. You will also need to then go to the boards manager and download the ESP8266 components. If you can't see the port your board is connected to, download the driver from here:
https://www.silabs.com/products/development-tools/software/usb-to-uart-bridge-vcp-drivers
I had also added the OneWire library to my Arduino: http://www.arduinolibraries.info/libraries/one-wire
Then the basic code was fairly simple:
#include <OneWire.h>
#define DS18S20_Pin D8
#define BLUE_PIN D6
#define GREEN_PIN D5
#define RED_PIN D4
OneWire ds(DS18S20_Pin);
int CURRENT_COL = RED_PIN;
void setup() {
Serial.begin(115200);
Serial.println("");
Serial.println("Hello ESP8266");
pinMode(LED_BUILTIN, OUTPUT);
pinMode(RED_PIN, OUTPUT);
pinMode(GREEN_PIN, OUTPUT);
pinMode(BLUE_PIN, OUTPUT);
float getTemp(){
//returns the temperature in Celsius
byte data[12];
byte addr[8];
if ( !ds.search(addr)) {
//no more sensors on chain, reset search
ds.reset_search();
return -1001;
if ( OneWire::crc8( addr, 7) != addr[7]) {
Serial.println("CRC is not valid!");
return -1002;
if ( addr[0] != 0x10 && addr[0] != 0x28) {
Serial.print("Device is not recognized");
return -1003;
ds.reset();
ds.select(addr);
ds.write(0x44,1); // start conversion, with parasite power on at the end
byte present = ds.reset();
ds.select(addr);
ds.write(0xBE); // Read Scratchpad
for (int i = 0; i < 9; i++) { // we need 9 bytes
data[i] = ds.read();
ds.reset_search();
byte MSB = data[1];
byte LSB = data[0];
float tempRead = ((MSB << 8) | LSB); //using two's compliment
float TemperatureSum = tempRead / 16;
return TemperatureSum;
void loop() {
digitalWrite(RED_PIN, LOW);
digitalWrite(GREEN_PIN, LOW);
digitalWrite(BLUE_PIN, LOW);
digitalWrite(CURRENT_COL,
HIGH);
digitalWrite(LED_BUILTIN, LOW);
Serial.println("LED OFF");
delay(1000);
digitalWrite(LED_BUILTIN, HIGH);
Serial.println("LED ON");
delay(500);
float temperature = getTemp();
String temp = String(temperature);
Serial.print("TEMPERATURE: ");
Serial.println(temp);
delay(250);
if (CURRENT_COL == RED_PIN) {
CURRENT_COL = BLUE_PIN;
} else if (CURRENT_COL == BLUE_PIN){
CURRENT_COL = GREEN_PIN;
} else {
}All this does is print the temperature to the serial and cycles through the RED, GREEN and BLUE colours
Quintin Balsdon
