The player is based on a Jensen JTA-230 Stereo Turntable, a low-end player I didn't feel bad destroying. I started with a rough idea- a player with a floating platter on top a nice piece of scrap wood I had around. From there, I've been using the Jensen as a known-working template, modeling parts by part, using similar dimensions.
Parts are designed in Autodesk Fusion 360 and printed on an Ultimaker 2.
TODO:
- Design automatic on-off when arm is moved to the center or side
- PCB
- Final assembly
Zach
Filip Mulier
Sam Ferguson
Dan Maloney
GPPK
Seems like a neat project, I am interested in building one.
The link that you included for the full write up does not work (Server not found error), could you either post the files on this page or give a link that works?
Also could you post a schematic and PCB files? If you post a schematic, I can design the PCB and get it printed. If it works I can throw the Eagle files on the page to help out with the project.
Cheer - Baird
