Based around an atmega32, the control board will control a solid state relay connected to a 2Kw heater inside my mash tun. The controller will also be connected to a pump that circulates the mash all the time. A ds18b20 is used to read the temperature to see if the heater will be on or off.
Data is displayed on a hd4478 compatible display.
Androiders
Solderking
Anas Raza Khan
