Configuration.h
Repetier firmware configuration.h file. THis is setup to work without the annoying LCD and instead uses a raspberry pi (octoprint / octopi) as the controling server over wifi.
h - 31.52 kB - 09/06/2017 at 16:12
Download
Pin numbers.txt
Pin numbers for the Melzi control board found on this prusa i3 clone. A Melzi board is the same as a "Sanguino" - select this option when compiling under the arduino IDE
plain - 1.12 kB - 09/06/2017 at 16:10
Download
Motor-block.STL
Support for the stepper motor, to allow it to hang off the machine frame
Standard Tesselated Geometry - 45.20 kB - 09/03/2017 at 21:21
Download
Dual-hot-end-assembly.STEP
Complete assembly of the geometry
step - 5.80 MB - 09/03/2017 at 21:09
Download
Upgrade-block.STL
Lower half of the housing for the dual V6 heads
Standard Tesselated Geometry - 5.59 MB - 09/03/2017 at 21:07
Download
cooling_manifold_a2.STL
Top half of the housing for the dual V6 heads
Standard Tesselated Geometry - 4.62 MB - 09/03/2017 at 21:07
Download
lower-manifold_a2.STL
Manifold for extruded material cooling fan
Standard Tesselated Geometry - 4.51 MB - 09/03/2017 at 21:07
Download
Slide-fixed.STL
V6 mount
Standard Tesselated Geometry - 39.14 kB - 09/03/2017 at 21:07
Download
Slide-adjust.STL
V6 adjustable mount
Download
GT2-clamp.STL
Clamp for the GT2 cable
Standard Tesselated Geometry - 51.06 kB - 09/03/2017 at 21:07
Download
dummy-extruder.STL
dummy extruder tube when using a single extruder
Standard Tesselated Geometry - 28.21 kB - 09/03/2017 at 21:07
Download
