1PIC Firmware
PICBasic firmware for PIC12F675
Define OSCCAL_1K 1 ' Calibrate internal oscillator LED Con 0 ENAB Con 5 STOPPED Con 4 ANSEL = 0 ' Set all digital CMCON = 7 ' Analog comparators off OPTION_REG.7 = 0 ' Enable WPUs Low LED mainloop: ' loop while not enabled IF ENAB = 1 THEN GOTO mainloop ENDIF ' loop if car not stopped IF STOPPED = 1 THEN GOTO mainloop ENDIF Pause 500 ' Delay for .5 seconds blinking: High LED Pause 300 Low LED Pause 500 ' car started moving, or green light disappeared? IF STOPPED = 1 OR ENAB = 1 THEN GOTO mainloop ENDIF GOTO blinking End
trax
