1Step 1
take old broken cpap apart
2Step 2
remove filters and clean motor
3Step 3
find wires going to the motor coils
4Step 4
connect motor to esc
5Step 5
upload the code to arduino
6Step 6
connect power brick
7Step 7
test and see if motor spins in the right direction (if it doesn't airflow will be low and pitch will be high)
8Step 8
cut and fasten menstruation pads put side by side
9Step 9
fasten motor to wooden box
10Step 10
try to make it neater than me
f3n0
