Quick and Dirty RPi bot
A automotive robot based on the RasPi platform and Lego hardware, easy to expand and repair.
This is a simple robot with a chassis completely made of Legos. Even the tires and motors are Lego. It's controlled by a Raspberry Pi powered by a LiPo battery.
To access the internet a WiFi USB dongle is attached.
The goal is to make the bot accessible via a VPN from around the globe to drive around the flat and check everything with the image feed from the USB webcam.
For additional devices it is equipped with a USB hub.
In the end it shall be able to be charged via induction or contacts at a charger station.
To power the system I'm using a standard 2200mAh 11.1V RC LiPo battery.
A LM2596 circuit provides the 5V for the Pi.
The Pi runs the standard OS Raspbian.
The extandability is given because of the versatility of LEGO.
Via a L293D H-bridge are the motos directly controlled using th GPIO pins.
I'm using the old 9V Lego Technic Motors.
  • 1 × Raspberry Pi
  • 1 × L293D Interface and IO ICs / Peripheral Drivers and Actuators
  • 1 × LM2596 Circuit Power Management ICs / Switching Regulators and Controllers
  • 1 × Breadboard Electronic Components / Misc. Electronic Components
  • 1 × LEGO TECHNIC 9V Motor Lego Motor
View all 10 components
  • Wifi and SSH
    marble08/20/2014 at 21:46 0 comments
    I've managed to confige the Wifi settings with wicd and established a SSH connection in my LAN
  • First motor test.
    marble08/20/2014 at 20:50 0 comments
    By manually manipulating the GPIO pins I got the motors running.
    The system works :-)
  • Powering the Pi
    marble08/20/2014 at 20:48 0 comments
    Adjusting the swithcing regulator circuit to 5V.
    By only powering the Pi, the current from the battery is 0.3A.
    2.2Ah/0.3A=7h
    Because of the efficency of 66.7% of the regulator it gets a little hot.
  • Chassis is ready
    marble08/20/2014 at 20:46 0 comments
    I've managed to build a Lego case aroud the Pi and the USB hub.
    Motors in the front. Spinnable wheel in the back.
View all 4 project logs
