Wifi and SSH
08/20/2014 at 21:46 • 0 commentsI've managed to confige the Wifi settings with wicd and established a SSH connection in my LAN
First motor test.
08/20/2014 at 20:50 • 0 commentsBy manually manipulating the GPIO pins I got the motors running.
The system works :-)
Powering the Pi
08/20/2014 at 20:48 • 0 commentsAdjusting the swithcing regulator circuit to 5V.
By only powering the Pi, the current from the battery is 0.3A.
2.2Ah/0.3A=7h
Because of the efficency of 66.7% of the regulator it gets a little hot.
Chassis is ready
08/20/2014 at 20:46 • 0 commentsI've managed to build a Lego case aroud the Pi and the USB hub.
Motors in the front. Spinnable wheel in the back.
