Project presentation video
10/13/2017 at 17:46 • 0 commentsHey, presentation video is added here
Very preliminary support for ESP32 added
10/05/2017 at 15:51 • 0 commentsAs a next step of FDIM controller evolution I'm trying to use ESP32 board as its heart. That should allow to read and write some cool text info as track names or navigation hints - and get this data via WiFi link or Bluetooth connection. Code compiles, but may need modification to Sodaq_DS3231 library - inclusion of pgmspace.h should be surrounded by ESP32 macro check (exactly as in can-clock.ino file)
Reverse engineered headlights status in Ford CAN
09/28/2017 at 10:21 • 0 commentsRecently reverse engineered headlights status in MS CAN messages. Already used in my other CAN project - CAN relay. But also can be used for this controller.
Status CAN ID b0 b1 b2 b3 b4 b5 b6 b7 Off 3C3 14 0 0 0 1 1 0 0 Low Beam 3C3 14 39 0 0 1 1 0 0 Autolamp 3C3 14 2 0 0 1 1 0 0 Autolamp (night) 3C3 14 3B 0 0 1 1 0 0 Marker light 3C3 14 1 0 0 1 1 0 0 High beam 3C3 16 1 0 0 1 1 0 0 Messages frequency - 0.2-1 Hz
Or, more meaningful by bits
Marker lights bit 0 of byte b1 - 0 - off, 1 - on .......M Low beam bits 3,4,5 of byte b1 - 000 - off, 111 - on ..LLL... Autolamp bit 1 of byte b1 - 0 - off, 1 - on ......A. High beam bit 1 of byte b0 - 0 - off, 1 - on ......H. b0 b1 000101H0 00LLL0AM -
Ford Dash Controller @ Moscow Mini Maker Faire
09/25/2017 at 13:08 • 0 commentsOn September 9th I've made a workshop "How to build DIY automotive electronics" at Moscow Mini Maker Faire. Been the only workshop with 16+ audience rating. Try to find me - should be easy even for non-Russian speakers :). Maybe next time I need to have more hacking rather than DIY audience, dunno. If you host car hacking conference and want me to talk on it - contact me :)
Slides are evolved version of Mail.ru DIY meetup talk. Updated English slides are coming soon.
