The initial prototype had 0.96" i2c OLED 128x64. The main benefits are
- only two connections (i2c) required from atmega micro-controller.
- 'high' resolution 128 x 64
on the negative side
- high power consumption ~ 10mA-20mA depends on number of visible pixels
- small display size
- high memory usage
The ATMega328P 3.3V will use around 3.5mA. We will have some losses on our Step-Up voltage regulator and other circuits but still 10 mA is a lot.
To reduce power consumption I have decided to move to Nokia 5110 84 x 48
- it consumes around 0.5mA and 1-10mA (for backlight)
- large display
- less memory usage
Downsides
- SPI interface more pin will be required
- low resolution
- It is less readable than oled
The connection requires at least 4 lines + 1 line for led but we will also lose MISO pin as it can not be reused as normal digital pin. In total 6
- SCE (CE) - GND
- RST - DigitalPin
- D/C (DC) - DigitalPin
- DN (DIN) - SPI MOSI
- SCLK (CLK) - SPI SCK
- LED (LIGHT) - PWN Digital Pin
- disconnected - MISO
The LCD is a separate module and can be easily detached from main pcb
