Video
03/13/2018 at 11:14 • 0 comments -
New PCB arrived
10/21/2017 at 11:40 • 0 commentsNew PCB arrived and tested. The fan speed can now be controlled by turning the potentiometer. For the battery I used a JST plug to get reverse polarity protection.
New PCB
09/17/2017 at 09:42 • 0 commentsI've added a potentiometer to the PCB to control the fan speed. The V1.0 board used a PWM pin, that does not support PWM. It is still possible to use one of the ISP pins (D11) which is directly beside the motor conector to use PWM control.
Video of one cycle
09/16/2017 at 09:47 • 0 comments
