Build Instructions Published
09/16/2017 at 01:31 • 0 commentsI just published the build instructions. The process is pretty straightforward, but please leave a comment if you have any questions or run into any problems.
GitHub Repo Now Available
09/15/2017 at 16:03 • 0 commentsWhile working on finalizing the installation instructions, I found that I had accidentally left the GitHub repo marked "PRIVATE". Sorry about that. It's public now, so if you tried to access it and were denied, please try again.
User Interaction
09/13/2017 at 22:41 • 0 commentsI had an hour or so this morning before work, so I decided to try coding up a simple method to allow the user to choose which object they'd like to locate. The planet finder has no monitor or keyboard, so previously I had hard coded the target just for testing, but now it was time to add some interactivity.
I toyed with the idea of making a simple web UI that you could use from your smartphone or tablet, but rejected that (for now). Yes, it'd allow you a lot of flexibility in selecting objects or even inputting your own orbital data, but when you involve the phone for a UI, you might as well use your phone's sensors for all the rest too, and skip the Pi altogether. No, I wanted something that could be done entirely on the device, from start to finish.
I ended up with simple Python routine that takes a list of possible objects and lets the user use the joystick UP/DOWN to cycle through them until the user clicks the button on one of them.
It's not perfect, but so far it's workable. I have some ideas about how to make it a bit nicer, but really the 8x8 LED matrix is a little limiting. But it's better than pairing it with a phone!
