Census of the gates
A project log for YGREC8
A byte-wide stripped-down version of the YGREC16 architecture
yann-guidon-ygdesYann Guidon / YGDES 04/21/2019 at 20:050 Comments
It's time for a little census.
[yg@Host-002 VHDL]$ grep -r 'entity' * |grep 'port' |grep 'map' |sed 's/.*entity //'|sed 's/ port.*//'|sort|uniq
AND2
AND2A
AND3
AND3A
AO1
AX1C
CLA3
INV
MX2
NAND2
NAND3
NAND3A
NOR2
NOR3
NOR3A
OA1A
OR3
XA1
XO1
XOR2
 (I removed the complex unit names by hand)
There are 20 gates so far, more, and more complex, than what #Shared Silicon provides (only INV, NOR, NOR3, NAND2, NAND3 and some T-gates).
I believe that by using more complex gates with more inputs (but reasonably so), there is a bit of performance and size benefit. I don't see any roadblock to get the missing gates : either I can make mine easily, or I borrow from existing free libraries.
Rich text editor
