Can you believe that the source code synthesised and place/routed on first try and reached an estimated 49MHz performance on A3P060 ?
The core occupies about 570 versatiles (3-input cells) which leaves 2/3 of the FPGA (1K LUT3) for GPIO and peripherals :-) [I originally expected about 700]
The source code is not used correctly (many registers are mapped to I/O pads, an artefact from the coding style) so performance can only increase and the system fits nicely in the small #ProAsic3-Stamp !
There is still a lot of work to do but it's looking great so far.
