I just thought about something else, which is a good argument FOR using a latch or flip-flop to drive certain control signals, in particular MUX2s:
MUX2 often needs complementary control signals. In A3P and other technologies, each MUX2 receives the control signal and implements an inverter inside the gate. However for ASICs can't always afford this luxury because the inverter would be uselessly duplicated, increasing latency and surface.
OTOH the latches and flip-flops usually work by looping two inverters back to each other and it's often possible to get the positive as well as the complementary output.
When signals are well routed, the control signal's latch can also serve as an inverter for free, there are 2× more signals (and double the load) but the logic complexity is reduced and uses fewer transistors. This is especially critical for the register set, to save room...
So while the FPGA version will use MUX2s for the latch and the register selector, the ASIC version will use a latch with 2 complementary outputs and the MUX2 is reduced to a simple gate that performs (A and B) or (C and D) (with for example B and D as control signals, using only 8 transistors in classic CMOS or 2/4 transistors with pass gates).
