The RES15 relay is nice but requires way too much current to operate, in particular in some circuits where low current is necessary : the DRAM sense circuit as well as the instruction sense circuit, because 16 bits multiply the coil current, that reaches a value that can't be reliable...
Another type of relay is required and @Artem Kashkanov suggested the RES55 : a reed-type relay with the typical fast operation and low operating current, though at a higher voltage.
I couldn't find a suitable lot of this reference on eBay but found 2 other things :
- RES-64A rated 9-11V : vintage, pretty bulky, only SPST but 2K ohm coil so it must be pretty sensitive
- 1A12 : miniature SIP chinese reed SPST relays, rated 12V, 1K ohm coil, very cheap
I just tested the 1A12 and I am impressed : the contact closes at about 5V (varies with the piece) and opens at about 3V, with a current under 2mA. With such a hysteresis and low power, it even becomes interesting to use them for the register set...
I still have to receive the RES-64A, which would look way better, and I'll have to compare it to the modern miniature version. However there is now a good solution to the problem I had before : I can switch 16 bits on, and draw at most 2×16=32mA, which will not strain the address decoder's contacts much.
Oh and I still have to design that automated relay tester...
And reed relays are pretty faster than usual one,. so It can be very helpful for DRAM refresh logic.
yes however they can handle/switch less current and most often are SPST. So I use them as "amplifiers" for now.
If I start to want to replace all the RES15 I'll need DPDT reed relays and they use a higher voltage so it would also change all the power supplies and topologies...
DRAM refresh logic will be quite simple, I think. With a sensitive current sensor, the capacitor can retain data longer and refresh slower, reducing the wear of all the contacts.
