jumping back and forth, and carry
A project log for YGREC8
A byte-wide stripped-down version of the YGREC16 architecture
yann-guidon-ygdesYann Guidon / YGDES 11/20/2021 at 15:340 Comments
Update 20231019 : The "carry trick" is dropped from the current ISA definition, as it applies only to forward jumps (IF blocks).
_____________________________________________
The Y8 can jump:
set label pc
it can also jump relative :
add (label-$) pc
and it can even jump relative conditionally :
add (label-$) pc ifc
But then the range is limited because only 4 bits are available for the the signed amplitude. And I have already sacrificed one condition bit...
With the new assembler, here is the best that can be reasonably done:
add (forward-$) PC ifnz
nop ; 1
nop ; 2
nop ; 3
nop ; 4
nop ; 5
nop ; 6
nop ; 7
forward:
backwards:
nop ; -8
nop ; -7
nop ; -6
nop ; -5
nop ; -4
nop ; -3
nop ; -2
nop ; -1
add (backwards-$) PC ifz
The output in .hyx:
;;hyx1
; L1: add (forward-$) PC ifnz
75BF ; @0: ADD   8 PC IFNZ
; L2: nop ; 1
0000 ; @1: NOP
; L3: nop ; 2
0000 ; @2: NOP
; L4: nop ; 3
0000 ; @3: NOP
; L5: nop ; 4
0000 ; @4: NOP
; L6: nop ; 5
0000 ; @5: NOP
; L7: nop ; 6
0000 ; @6: NOP
; L8: nop ; 7
0000 ; @7: NOP
; L9: forward:
; = 8
; L11: backwards:
; = 8
; L12: nop ; -8
0000 ; @8: NOP
; L13: nop ; -7
0000 ; @9: NOP
; L14: nop ; -6
0000 ; @10: NOP
; L15: nop ; -5
0000 ; @11: NOP
; L16: nop ; -4
0000 ; @12: NOP
; L17: nop ; -3
0000 ; @13: NOP
; L18: nop ; -2
0000 ; @14: NOP
; L19: nop ; -1
0000 ; @15: NOP
; L20: add (backwards-$) PC ifz
77C7 ; @16: ADD  -8 PC IFZ
;;;; SYMBOL DUMP :
; * 'FORWARD'=8 ref:1 / sym_usr
; * 'BACKWARDS'=8 ref:1 / sym_usr
A backwards loop could then contain 8 instructions (including a test for the end of the loop) but the forward jump can only skip over 7 instructions, despite the ability to encode the constant 8 when dealing with the PC register.
The offset 1 is still possible and this represents the next instruction, which would be trivial to execute otherwise. And the offset 8 points to the 8th instruction after the skipped block, it's not the size of the skipped block.
At least it's now impossible to do a pointless loop such as
ADD 0 PC ifnz ; spin endlessly doing nothing
To achieve a more practical goal, the operand should be the NPC, or PC+1, which is being computed at the same time as the addition. But this creates a whole lot of troubles, in particular:
At this point, the "short add trick" requires only a few logic gates (to detect the opcode, the format and the sign of imm4, detecting the PC register is not even necessary) and no deep modification of the state machine.
Trying to squeeze one more instruction, to skip 8 opcodes, would complicate the whole circuit with quite little benefits...
Rich text editor
