It's a tank to use.
JPEG Image - 2.24 MB - 09/18/2017 at 15:09
Preview
It's an electro valve to use.
JPEG Image - 1.83 MB - 09/18/2017 at 15:09
Preview
It's a module SIM800L.
JPEG Image - 134.12 kB - 09/18/2017 at 15:09
Preview
It's a sensor DHT11.
JPEG Image - 81.98 kB - 09/18/2017 at 15:09
Preview
It's a Display LCD16x2.
JPEG Image - 11.05 kB - 09/18/2017 at 15:09
Preview
It's a DS18B20 to use without the protected cable
JPEG Image - 26.58 kB - 09/18/2017 at 15:09
Preview
It's a DS18B20 to use with the protected cable
JPEG Image - 20.83 kB - 09/18/2017 at 15:09
Preview
sensorOpticoSilkscreen.pdf
Board of connection to the Optical Sensor to measure the level of the tank. Silkscreen.
Adobe Portable Document Format - 3.21 kB - 09/18/2017 at 14:59
Preview
sensorOpticoSoldierMask.pdf
Board of connection to the Optical Sensor to measure the level of the tank. Top layer or Soldier Mask.
Adobe Portable Document Format - 1.75 kB - 09/18/2017 at 14:59
Preview
ldrPlacaSoldierMask.pdf
Board of connection to the LDR. Soldier Mask or top layer.
Adobe Portable Document Format - 1.38 kB - 09/18/2017 at 14:58
Preview
ldrPlacaSilkscreen.pdf
Board of connection to the LDR. Silkscreen.
Adobe Portable Document Format - 2.24 kB - 09/18/2017 at 14:58
Preview
dht11PlacaSoldierMask.pdf
Board of connection to the DHT11. Soldier Mask or Top layer.
Adobe Portable Document Format - 1.54 kB - 09/18/2017 at 14:56
Preview
dht11PlacaSilkscreen.pdf
Board of connection to the DHT11. Silkscreen.
Adobe Portable Document Format - 2.27 kB - 09/18/2017 at 14:56
Preview
circuitoControlValvulaSilkscreen.pdf
Control circuit to the electro valve. Silkscreen.
Adobe Portable Document Format - 3.90 kB - 09/18/2017 at 14:55
Preview
circuitoControlValvulaLayer.pdf
Control circuit to the electro valve. Top Layer.
Adobe Portable Document Format - 2.36 kB - 09/18/2017 at 14:55
Preview
JPEG Image - 10.95 MB - 09/18/2017 at 14:50
Preview
Datasheet Sim800L.pdf
It's a datasheet of module SIM800L who connect the system with the web page and sending the sms text.
Adobe Portable Document Format - 2.70 MB - 09/18/2017 at 14:48
Preview
User Manual Nucleo-F401RE.pdf
small user manual of the 64 core board.
Adobe Portable Document Format - 3.37 MB - 09/18/2017 at 14:48
Preview
JPEG Image - 3.07 MB - 09/18/2017 at 14:47
Preview
Datasheet MOC3041.pdf
Adobe Portable Document Format - 298.85 kB - 09/18/2017 at 14:46
Preview
Datasheet DS18B20.pdf
This is the datasheet of the sensor DS18B20 to measure the soil temperature. This works with the 1wire comunication.
Adobe Portable Document Format - 484.15 kB - 09/18/2017 at 14:46
Preview
Datasheet DHT11.pdf
This is the datasheet of the sensor DHT11 to measure the ambient temperature and the humidity ambient relative.
Adobe Portable Document Format - 842.29 kB - 09/18/2017 at 14:45
Preview
Datasheet Soil Moisture Sensor.pdf
This is the datasheet of the Higrometer to measure the soil humidity. It's an analogic sensor.
Adobe Portable Document Format - 631.24 kB - 09/18/2017 at 14:45
Preview
STM32 Nucleo 64 Board.pdf
A little bit document to explain the Nucleo Board 64 used.
Adobe Portable Document Format - 257.14 kB - 09/18/2017 at 14:45
Preview
LCD Connection to a microcontroller.
JPEG Image - 179.19 kB - 09/18/2017 at 14:44
Preview
It's a connection to bus 1wire.
JPEG Image - 22.22 kB - 09/18/2017 at 14:44
Preview
Resistance Code.
JPEG Image - 43.38 kB - 09/18/2017 at 14:44
Preview
Using a UART to Implement a 1-Wire Bus Master.pdf
Adobe Portable Document Format - 148.89 kB - 09/18/2017 at 14:44
Preview
Connection to DHT11
JPEG Image - 8.33 kB - 09/18/2017 at 14:44
Preview
