==================ATTENTION TIME TRAVELERS==================
PLEASE CONTACT ME YESTERDAY SO I CAN BUILD AN ACTUAL
PROOF OF CONCEPT OF THIS BEAUTY.
I intend to implement an emulation of a Time-Traveling module for ridding us from the tortures of Pipeline Hazards forever.
The simulation will consist of an LPCXpresso LPC1115 microcontroller simulating a machine with such improvement in its pipeline.
The main purpose is to have this built in future microprocessors.
The simulation will have all of the relevant data shown in a TFT touch sensing display.
The following text is verbatim from the Blog post mentioned in the description :
Flux Capacitors might help prevent pipeline hazards
First off, this is not serious at all. Okay, you've been warned.
Ever wondered about alternative approaches to overcome Pipeline Hazards?
Well, looking at this xkcd schematic I started to wonder about the Flux Capacitor's potential in an actual circuit. I'll tell you what made sense in my head, but first, let me explain the basics. If you already know the basics, you may skip to "Flux Capacitors in Computers".
About Pipelining
It's a way of speeding up code execution by dividing it into several stages that perform sub-tasks simultaneously by means of dedicated hardware for each stage. Four consecutive stages are typically used: Fetching the instruction from memory, Decoding it (identifying the operation),Executing the instruction, and Writing Back the result. This ultimately speeds execution up (ideally in a rate equal to the number of stages in the pipeline). Read more.
Pipelined execution. Numbers shown in the graph are the instructions at the left.
About The Hazards
Hazards are problems related to the use of a pipeline in an instruction execution unit. Two Hazards are considered here:
- Data Hazards: It happens when an instruction needs data that's produced by another instruction that previously entered the pipeline, but hasn't finished yet. For example let's say instruction i writes data into register A, and instruction i+1 (the next one) uses register A as an operand to calculate something else. What happens when instruction i+1 is in the Execute stage and i is in the Write Back stage? The value of register A used by i+1 as an operand will be the original value prior to the execution of instruction i because it's not done yet. This is called a Read After Write (RAW) or true data depencency. This is a problem because the data used by instruction i+1 is outdated.
Data Hazard between Execute and WriteBack (may happen between other stages)
- Control Hazards: This concerns branches, calls, interrupts, exceptions, resets, etc. When sequential execution must change due to a branch or whenever the next instruction to fetch is not the next stored instruction, the Fetch stage must be aware of the address of the next instruction (branch target, interrupt vector, etc). Furthermore, most branches are conditional, and it's not until the Execute stage that the processor knows whether or not the branch should be taken. This is a problem because when the processor becomes aware of a branch, all of the instructions previously loaded into the pipeline might have to be aborted (execution may have to jump elsewhere). This abort depends on the condition of the branch, which will be known after Decode. If the branch must be taken, the pipeline must be flushed or bubbled (instructions previously entered replaced by NOPs [no operations]). If not, no problem. Flushing/bubbling the pipeline is a problem because it's a waste of time, and the pipeline is supposed to speed things up.
Control Hazard with bubble
There are many approaches to overcome these hazards, mainly divided in two kinds of strategies: Static...
Eduardo Corpeño
