11Step 11
Because the wireless module needs 3 volts, we will need to modify the teensy to run at 3 volts by cutting some traces and adding a voltage regulator. Instructions for this are on the teensy website.
12Step 12
Attach the other nrf24l01 wireless module to the teensy.
13Step 13
Put the teensy in some sort of enclosure. I used a pill bottle.
To make the wire go through the cap, I drilled a hole just big enough for the wire, then cut a slit in the side to slide the wire in.
14Step 14
Now just record your macros. I wrote a program for this, but you dont need to use it.
click a switch, click record, type your keys, hit record again when done.
once all your keys are set how you like em, click the generate code button and the code for the teensy will be copied to your clipboard.
paste the code into the arduino ide, select the teensy board, set it for 8MHz clock, and program it.
15Step 15
enjoy your keypad.
