Will it work on a Pi? Yes!
09/25/2017 at 10:13 • 0 commentsI decided to test the scaled using a Raspberry Pi instead of a PC to try and make it more portable. The result was that it worked with a Raspberry Pi Zero W okay. It was a little sluggish but that was okay. The problem was without sound on the card I was better using a normal Pi. I also tested a Raspberry Pi 2 with a bluetooth dongle that was not much slower. All the tests were done with Raspbian.
In the end I decided I was not using it enough to solve this problem that in many ways was not a problem. It is a problem that can be solved though.
Wii Fit Balance Board Battery Usage
09/25/2017 at 10:05 • 0 commentsOne question that is asked a lot online is how long does a set of batteries last in the Wii Fit balance board. I know because I was one of the people looking and mostly finding others asking, or answers that varied a lot.
I can say that I put in a set of Maplin home brand batteries (that are good value when they are on offer) and they have run for 20 hours already. The voltage has dropped a little so I don't know how much longer they have but I will keep going with them and find out.
Everyone else has reported a much lower time so I suspect that the board uses less power when no one is standing on it. This would explain why I am getting 2.5 times more use than anyone else.
Also it may or may not draw power when not in use. An old set of batteries went dead when the board was in the store that implies it does. Equally they could have been "borrowed" and put back flat. Currently I take the batteries out when not in use and that solves the problem for both potential causes.
Alistair MacDonald
