Hackaday.io Hackaday.io
Sign up Log in
Word Alarm Clock with a Touch
A front cover for a classic word alarm clock with touch interface.
cfCF
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1k views
4 comments
154 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 4
View Gallery
1k
4
154
12
Team (1)
  • cfCF
Join this project's team
hardware
completed project
Related lists
Look at this
Just good looking projects made on Hackaday
This project was created on 09/25/2017 and last updated 8 years ago.
Description
An addition to a classic word alarm clock: A touch front cover. It's made of a PCB, with some electronics on the back to recognize the touch at each word. So you're able to control the clock by just touching it. You can set the time, alarm time and many other things.
On the backside there are two MPR121 for 24 different areas, which can be recognized. Since they run only at 3.3V some more parts were needed. The communication with the clock runs over I²C.
Details
Log In/Sign up to comment
Sign up with Github
OR
Gijs Withagen wrote 02/10/2019 at 20:06 • point
Do you share some more details anywhere? My daughter would love to have a clock like that next to her bed.
CF wrote 02/10/2019 at 20:13 • point
If you want a touch-version like the one shown here, I can't help you since the ICs I used for the touch-interface are not produced anymore. If you want a normal word-alarm clock, I can offer electronic kits and fine wooden housings. Check it out: https://du-kannst-mitspielen.de/elektronik/platine-wortwecker-135x135-tht/ You can also write me a mail and I can send you more details.
chaterrony wrote 05/20/2018 at 19:19 • point
Nice feature. The MPR121 only works if you touch them? Is your surface conductive? Or does it work on distance too?
CF wrote 09/27/2018 at 19:55 • point
You can set a threshold so that it works also on distance. The front panel is a PCB with copper areas surrounding each word on the backside.
VFD Clock on soviet IV-6 7-segment tubes with Wi-Fi on ESP8266 MCU
Project Owner Contributor
ESP8266 VFD Clock
artem-kashkanovArtem Kashkanov
Create a fully functional LED clock from schematic to PCB using only a web browser and EasyEDA Pro.
The Clock Project
robert-feranecRobert Feranec
xkcd Comic turned into a clock
Factoring the Time
treibairtreibair
It displays hours, minutes and ... your birthday
Roman LED Clock
remconlremcoNL
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Word Alarm Clock with a Touch", please tell us the reason.
Send message
Remove Member
