A front cover for a classic word alarm clock with touch interface.
If you want a touch-version like the one shown here, I can't help you since the ICs I used for the touch-interface are not produced anymore. If you want a normal word-alarm clock, I can offer electronic kits and fine wooden housings. Check it out: https://du-kannst-mitspielen.de/elektronik/platine-wortwecker-135x135-tht/ You can also write me a mail and I can send you more details.
Nice feature. The MPR121 only works if you touch them? Is your surface conductive? Or does it work on distance too?
You can set a threshold so that it works also on distance. The front panel is a PCB with copper areas surrounding each word on the backside.
Do you share some more details anywhere? My daughter would love to have a clock like that next to her bed.
