In general my Idea was to use a BT Master Module (Tried with EGBT-045MS (as i assumed)..)
I thought it would report identificable BT Devices. Somehow it nearly doesn't respond anymore if i set it to Mastermode and Inquire.
After Getting the BT ID, i would check if the RSSI is over a certain threshold and enable a Button to unlock the door... But first i have to find an other BT Master module or get it running ...
There were some automatic garage door openers with bluetooth headsets on hackaday once... that was cool too :)
