testing the LF version of the PIC
10/18/2017 at 04:37 • 0 commentsI tested it now with a PIC12LF1572 and a clean setup with a new breakout board: At 1.8 V it needs 11.9 nA and at 3.3V it need 13.3 nA in sleep mode. The project file is updated. Maybe a new clean test setup helped as well, with only the microcontroller and a 100 nF capacitor between VDD and VSS:
low-power tests
09/26/2017 at 21:42 • 0 commentsSome more measurements with 3 V supply voltage:
- original code: 6.4 uA
- with brown-out reset disabled (#pragma config BOREN = OFF) it needs only 2.8 uA
No more ideas, waiting for an answer from Microchip support now.
Frank Buss
